i just build new pc. open bios chabìnged xmp  and set boot to dvd drive , the window wont show up.
plz help.
asus z97a
i7 4790k
gtx 970
---Me Rig---
-CPU-
Intel i7 4790k
-GPU-
Gigabyte 970 g1
-STORAGE-
250gb ssd
Western Digital 1tb HDD
-RAM-
(2x4gb)
-PSU-
EVGA supernova 850w gold+
-MOBO-
ASUS z97-a
-CASE-
Some ATX Sized No-Brand
-PERIPHERALS-
Some Mouse and Keyboard.
https://linustechtips.com/topic/266527-new-build-boot-problem-plz-help/
Can you still get into bios?
yes
nothing come liek teh dot line for window but it open the bios after 10 second
---Me Rig---
-CPU-
Intel i7 4790k
-GPU-
Gigabyte 970 g1
-STORAGE-
250gb ssd
-RAM-
(2x4gb)
-PSU-
-MOBO-
ASUS z97-a
-CASE-
-PERIPHERALS-
Are any of the error lights on your motherboard on?
there are red lights that turnon one by one one by one also yhere is sound of a tii when ever I start it
---Me Rig---
-CPU-
Intel i7 4790k
-GPU-
Gigabyte 970 g1
-STORAGE-
250gb ssd
-RAM-
(2x4gb)
-PSU-
-MOBO-
ASUS z97-a
-CASE-
-PERIPHERALS-
i just build m pc last night, asus z97a + i74790k   i burn the disk myself using img burn but the disk dont boot ,
any help
---Me Rig---
-CPU-
Intel i7 4790k
-GPU-
Gigabyte 970 g1
-STORAGE-
250gb ssd
-RAM-
(2x4gb)
-PSU-
-MOBO-
ASUS z97-a
-CASE-
-PERIPHERALS-
I'm going to guess this is a Windows disk?
And by that do you mean that you get something on screen, but Windows wont load- or nothing on screen?
the bios open after few seconds , even i set the boot to dvd drive , it just dont boot,
---Me Rig---
-CPU-
Intel i7 4790k
-GPU-
Gigabyte 970 g1
-STORAGE-
250gb ssd
-RAM-
(2x4gb)
-PSU-
-MOBO-
ASUS z97-a
-CASE-
-PERIPHERALS-
Does the drive show in BIOS? The list usually contains items that aren't even connected. If you see two options for the drive, try both of them.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
there are only two options , ssd and dvd-drive,  tonight i will try with usb to see if that works
otherwise does anyone knows any good video to burn the win7
---Me Rig---
-CPU-
Intel i7 4790k
-GPU-
Gigabyte 970 g1
-STORAGE-
250gb ssd
-RAM-
(2x4gb)
-PSU-
-MOBO-
ASUS z97-a
-CASE-
-PERIPHERALS-
Ok. The burning should be easiest part. I use Deepburner for all .iso burning. Most people use imgburn but its no matter. You can validate that disc works by booting with it on machine you have just used to burn it. Its more likely that the original file is corrupted than that burning process has had errors.
