Install
ndiswrapper-utils-1.9
ndiswrapper-common
from the softwarecenter and use the windows driver to install your device properly. It needs a reboot to work after installing the driver.
Is there a chance you could link me a guide or a video? Every time I try it says 0 packages updated and installed and 250 packages remained the same.
https://linustechtips.com/topic/266415-help-ubuntu-networking/#findComment-3620094
