Posting Issue
Go to solution Solved by 79wjd,
yeah
An Asus Z97-A doesn't have a power button on the motherboard.
Either connect the power headers with something like a fork, or flip the switch on the psu.
the switch on the psu, or the power button on the case (or just connecting the power button header on the motherboard for a few seconds -- something like a fork works well).
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/266379-posting-issue/#findComment-3619038
by the pw switch do you mean the motherboard switch
Does your motherboard have an actual power switch on it? Not all do -- in fact most don't; but if yours does, press it/hold it.
PSU Tier List | CoC
https://linustechtips.com/topic/266379-posting-issue/#findComment-3619061
yeah
PSU Tier List | CoC
https://linustechtips.com/topic/266379-posting-issue/#findComment-3619085
it does
then press it
Edit: of course they put it at the bottom of the board and not the top right like every one else......
PSU Tier List | CoC
https://linustechtips.com/topic/266379-posting-issue/#findComment-3619217
