It's incredibly overkill, it's pure luxury unless you plan to do some seriously extreme things. Overpriced IMO
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
The Build is just about looks and to be honest I think everybody can agree with me the look of that moterboard is the best on the whole Z97 chipset (k the ASUS Marsk S can compeete)
@RockiLocky
Both Linus and TTL did a review video IIRC, but be aware, that you pay a lot for brand, looks, features you may not need/use and a waterblock. If you are fine with that, go ahead, if not, it might not be your best option.
[Main rig "ToXxXiC":]
CPU: Intel Core i7-4790K | MB: ASUS Maximus VII Formula | RAM: G.Skill TridentX 32GB 2400MHz (DDR-3) | GPU: EVGA GTX980 Hydro Copper | Storage: Samsung 850 Pro 256GB SSD + Samsung 850 EVO 1TB SSD (+NAS) | Sound: OnBoard | PSU: XFX Black Edition Pro 1050W 80+ Gold | Case: Cooler Master Cosmos II | Cooling: Full Custom Watercooling Loop (CPU+GPU+MB) | OS: Windows 7 Professional (64-Bit)
@RockiLocky
What would you recommend me instead of the formula then?
Do you think the MSI Gaming 9AC is good?
Well, as you can see in my signature, personally I did go with the Formula, and yes, it was mainly for looks and the waterblock (features didn't hurt either), and I've always liked ASUS and their ROG brand when it came up - so for me it was the right choice. Just like to make sure other people know what they pay for (and what they will get), if they do.
I haven't had boards other than ASUS for a long time, so my personal experience with other manufacturers and their boards is exactly zero, so I won't comment on their products (although Gigabyte, MSI and Asrock do have good stuff as well).
If you like ASUS ROG design/looks you might check out the Maximus VII Hero (or Ranger), or for a basic board with all normal features, check the ASUS Z97-A or Z97-AR
Or any other board of the big four manufacturers - there's not much that could go wrong with their Z97 boards.
SO how is the experience with the Formula can you tell me how it is?
So far, just as expected. It runs, everything works, while looking good. Nothing more, nothing less. After all, it is just a motherboard, nothing magical going to happen that would make people scream OMG! ;)
How is the sound of it, heard it has the best onboard sound
Can't complain... but I need to get some betters speakers and headphones if I want to really judge audio quality. And those are way down on the bottom of the list...
