case fans
Go to solution Solved by STRMfrmXMN,
thanks bae
No problem babe.
I think I have some Noctua NF-P14 PWM fans in my system at the moment, they're pretty good. The motherboard controls them based on how hot the system is.
In terms of fitting them, unscrew the old ones and screw in the new ones
And I hate to compliment someone on something twice, but what a very topical username you have
Compatible with Windows 95
https://linustechtips.com/topic/265920-case-fans/#findComment-3613370
what are good case fans and how many can I fit into this case Azza CSAZ-XT1 B ATX Full Tower Case thanks in advance
Cooling System:
230mm Fan 1x230mm Red/Blue LED fan on the top 140mm Fan 1x140mm Red/Blue LED fan on the side,1x140mm LED in front 120mm Fan 1x120mm Fan in Rear
https://linustechtips.com/topic/265920-case-fans/#findComment-3613371
you told me this on my first post remember ;)
Hi friend.Who are you?
https://linustechtips.com/topic/265920-case-fans/#findComment-3613393
you my best friend I am not jokeing  bae look at friends list
Are you cheating on me with Linus  :angry:
It's over. Bye.
https://linustechtips.com/topic/265920-case-fans/#findComment-3613466
It's over. Bye.
no I am defintl not cheating on you with LInus because I've got my puppy in my lap my cute sweet puppy who barks and bites screw you pupanyways bae I am going to carry this on in a message
https://linustechtips.com/topic/265920-case-fans/#findComment-3613498
