Xbox 360 Wireless Controller
Go to solution Solved by LogicalDrm,
http://www.howtogeek.com/178881/ask-htg-how-can-i-hook-up-my-xbox-360-controllers-to-my-computer/
found this website. he bought something thats not really microsoft device. but some dude did a tutorial? should it still work? sorry for being stupid or something.
The guide seems legit and since people can get PS3 controllers working on PC, it would be worth of trying. It still isn't bluetooth as Xbox controller works with radio signal rather than with BT. Whether you want to go through with cheaper adapter and more configuring or buying actual adapter and installing drivers semi-automaticly, is up to you.
Nope.......i wish as well,so i good play split screen games with my neighbors with his controller
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
no, you can however just buy an adapter on ebay or somewhere else.
up up and away!
Did it work?
ExSystems
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
didnt know xbox 360 controller works with radio signal rather than bluetooth. now i dont have to try bluetooth. :) thank you. the question now is "will 1 receiver be able to support 2 wireless controllers" time to google. :D
