Xbox One Controller Wireless PC
So I was wondering if there is anything I can buy that would make my Controller work wirelessly with my PC, I know I can use the charging cable and it will work but I want it wireless.
Thanks
CPU:i7 4770k, Motherboard:ASUS Z79-AR, RAM:8GB HyperX Beast, GPU:EVGA GTX 970 4GB, Case:Corsair 600T, Storage:1TB Seagate Barracuda, 120GB Sandisk SSD, 256GB Sandisk SSD, PSU:Corsair TX650M, Display(s):Asus VE247H, Asus VE247N, Cooling:Corsair H60 with NF-F12, Keyboard:Razer BlackWidow, Mouse:Razer DeathAdder, Sound:Astro A40
https://linustechtips.com/topic/265718-xbox-one-controller-wireless-pc/
Linus made a handy tech about it can't remember which episode though.
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
Nope, nothing yet.
Thanks
May I ask why the One and not 360? Do you just happen to have the One controller lying around and are trying to find a solution? I would totally understand if that were the case.
But I personally find the 360 controller to be much more comfortable. Maybe that's just me.
I have both controllers and I just prefer the Xbox One controller compared to the 360.
I'd use the 360 wireless then as you can do that with the right sort of adapters.
