ok, so recently I was going to spend a good bit of money on a computer for the YouTubes, but something came up and I had to spend the money else where, but my dad is about to upgrade from a Microsoft surface pro to a surface pro 3 and he said he might give me his old surface pro  and I was think that there could be a way to set the surface pro up for YouTube. so anyways I was thinking that I could use a avermedia live gamer portable with it. but I couldn't figure out how I could record audio with gameplay and what not. I thought I could maybe get a usb hub and plug it all up to that but if you use a Yeti microphone witch uses a usb interface, you wouldn't be able to record the audio because it would be running through the computer and not the capture card (if that makes since). If there is a way to do it please help me out and tell me!!
https://linustechtips.com/topic/265640-surface-pro-youtube-setup-help/
Why not record your voiceover and add it later in editing?
Can you not connect the live game to the surface pro using USB? and then connect your yeti too?
I guess I could do that but I have no clue how to set that up, also there's only 1 USB port on the surface pro, so i would have to get a usb hub, but from what I have read online you have to have a audio plunged into the live gamer portable so that will just record the audio and gameplay at the same time.
Yeah just get a USB hub
AFAIK the live gamer portable does not have a way of connecting USB microphones, only 3.5mm ones, so you either need a different mic/headset or to just record your audio seperately and edit them together
Well is there a way to convert it to 3.5mm? Becuase I'm really set on using a yeti but I dont want to have to edit them together.
Nope, sorry I dont think there is a way to do it using the gear that you have
Can you not connect the live gamer to the PC? and then in the livegame software tell it that your yeti is your microphone?
Dang, well I'm not sure if you can there might be a way but I'm not sure, I'll have to have a look around on the web
I now nothing about the subject, but if your USB equipment draws a lot of power, you may want to be looking at a powered USB hub, as the USB port can deliver only so much power. So while it is fine for 1 device, sharing power with 2 power hungry might cause issues.
You can record a separate audio track. It's an option within the software, the video file will have the ingame audio, while it records a separate commentary audio file that you can mix in post.
All you need is a powered usb hub and you'll be fine.
Ya I was looking for one on Amazon at the moment but for some reason I can't decide on one lol
Ya but I don't want to have to edit them together, but it looks like I have to
