When i launched the program it says, "Enumerating Display Devices Phase 1" then it just crashes and says "Display Pilot has stopped working, A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available."
Can someone please help me??
CPU: AMD FX-8350
GPU: Sapphire Vapor-X HD 7970 GHz 3GB
OS: Windows 8.1 64-bit
Monitor: Benq XL2720Z
https://linustechtips.com/topic/265532-benq-display-pilot-problem/
  • 1 year later...
