Today I found a stick of 2GB DDR3 1333 for $1 LOL!
Couldn't pass the offer so I snatched it immediately.
Now my question is since my system as 2 sticks of 4GB DDR3 1600 memory, is it okay to just shove that stick in and make it 10GB?
Also will this cause worse performance of my 1600 RAM even though there may be a possibility that I can overlock via MB to make them all 1600.
But it sorta still breaks the dual channel rule.
tldr:
Am I better off with:
2x 4GB 1600 DDR3
OR
2x 4GB 1600 DDR3 + 1x 2GB 1333 DDR3
Because I could just leave it lying around as a spare.
https://linustechtips.com/topic/265314-memory-mixing-advice/
2X4 GB let go your other stick it will just create instability and problems.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/265314-memory-mixing-advice/#findComment-3606489
instability is unlikely. Depends on the brand. If your system is stable from using that third 2 gig stick, the only thing that will happen, is your 2 4gig sticks will downclock to 1333. If you're overclocked at all using bclock, that would be the only thing that would cause instability. You might have to reconfigure your overclock. If an extra 2 gigs of ram is worth it to you, do it.
You're not going to notice any performance decrease dropping from 1600mhz to 1333. None.
Edit: Also, it does not break any dual channel rule. You still have 2 4 gigs sticks in dual channel. An extra stick in a non-dual channel slot isnt going to turn off dual channel mode.
CPU: Ryzen 5800X | GPU: RTX 3080 FE | Board: x570 Aorus Master | RAM: 32GB GSkill TridentZ | Case: Phanteks 719
https://linustechtips.com/topic/265314-memory-mixing-advice/#findComment-3606500
...in regards to gaming...if you happen to do video editing and rendering, modeling, photo editing and things of that nature then dropping the memory speed to 1333mhz will hit your performance and i would rather have only 8gb in that case.
https://linustechtips.com/topic/265314-memory-mixing-advice/#findComment-3606504
I guess? Performance drop even in rendering/modelling isn't going to be that drastic, it certainly won't be night and day and he likely won't even notice it. It really comes down to, how much ram does he typically use day to day. if it's pushing 7/7.5 gigs, he could benefit from the extra ram.
https://linustechtips.com/topic/265314-memory-mixing-advice/#findComment-3606514
correct, but for MOST users 8GB is still plenty (i'm a poweruser i render videos and play games on the side and i never cap out my RAM in windows 8)
https://linustechtips.com/topic/265314-memory-mixing-advice/#findComment-3606522
Really? Jeez. 8 gigs was getting way too limiting for me. 10 gigs is kind of a sweet spot for my uses for now.
https://linustechtips.com/topic/265314-memory-mixing-advice/#findComment-3606527
farcy4 and cod AW do eat up 6 to 7 gigs so when i play those i can't do much else...but other than that most games still use 4gb or less (i would want to upgrade to 16gb really, but i can't find a way to justify this purchase just now...will happen someday though)
https://linustechtips.com/topic/265314-memory-mixing-advice/#findComment-3606541
I am thinking of upgrading to 32GB as 16GB is starting to feel like not enough.lol
i find that very hard to believe, what do you do with your machine that sucks so much RAM? Autocad? (cause at work i work with autocad map and i do use upward of 16GB when i load many maps and work on several project at once, but in my home/recreation use i never use more than 7gb.)
https://linustechtips.com/topic/265314-memory-mixing-advice/#findComment-3606613
