Was that boost specifically for ordering the game as a pre-purchaapurchase, or am I able to get it now with a purchase of the retail game?
Thanks
Upcoming build: 4790k OC @ 4.6Ghz, Dual MSI 980 Twin Frozr V, 16 GB Vengeance Pro 2133Mhz RAM, 760T Corsair Case w/ Razer Blackwidow Chroma
https://linustechtips.com/topic/264769-level-90-wow-boost/
Great thanks :-)
beware, before you get all skills, you must complete introductory missions.
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
https://linustechtips.com/topic/264769-level-90-wow-boost/#findComment-3600622
@OllieBarrie
Just switch specs and you'll unlock everything right off the bat.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/264769-level-90-wow-boost/#findComment-3608248
Why would you do that anyways, it doesn't even take a level to get all your spells back
Switching specs take 3 seconds...why would you want to spend any more time than that to slowly get your skills....?
https://linustechtips.com/topic/264769-level-90-wow-boost/#findComment-3610141
You can't switch specs with a freshly boosted 90, they don't have dual spec yet
Then go to your class trainer and learn it... you get ported to your main city when you boost anyway.
https://linustechtips.com/topic/264769-level-90-wow-boost/#findComment-3613659
You get given dual spec, you can switch specs to get your spells and Blizzard said this a while ago. They put that in so people with knowledge of the game don't have to go through the leveling area for their spells.
i7 6700K - ASUS Maximus VIII Ranger - Corsair H110i GT CPU Cooler - EVGA GTX 980 Ti ACX2.0+ SC+ - 16GB Corsair Vengeance LPX 3000MHz - Samsung 850 EVO 500GB - AX760i - Corsair 450D - XB270HU G-Sync Monitor
i7 3770K - H110 Corsair CPU Cooler - ASUS P8Z77 V-PRO - GTX 980 Reference - 16GB HyperX Beast 1600MHz - Intel 240GB SSD - HX750i - Corsair 750D - XB270HU G-Sync Monitor
https://linustechtips.com/topic/264769-level-90-wow-boost/#findComment-3614467
They HAVE to go through that leveling area anyways. I have knowledge about the game, yet I never bothered to switch specs when I did my boost.
https://linustechtips.com/topic/264769-level-90-wow-boost/#findComment-3618417
