@Dave91 What's your PSU and what's the GPU you want? You probably can, but it's best we check.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/264589-pcie-pin-connectors/#findComment-3598467
I just wonder if i could use etc. one 4pin to molex
if i dont have enough cables directly from the PSU?
This would honestly depend. I would only suggest using a molex to PCIe power connector if you have a quality power supply. If you have a generic branded unit and not enough PCIe power connectors, then chances are you don't have enough power. However the best way for us to find out would be letting us know which PSU you have, and which GPU you are planning to buy.
"Rawr XD"
https://linustechtips.com/topic/264589-pcie-pin-connectors/#findComment-3598496
wow. quick answer!
its "Advance TX-750" <-- 750w
I was planning to buy "xxxx Gtx 760/770"
or something similar!
ow. quick answer!
https://linustechtips.com/topic/264589-pcie-pin-connectors/#findComment-3598665
ow. quick answer!
Then that should work fine. But I've never heard of that brand so it's kinda scary to me.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/264589-pcie-pin-connectors/#findComment-3598680
