WUs stuck at 99.99%?
Solved by tobben,
I'll give it another day but if it isn't done by then it's getting scrubbed.
Thanks for the replies.
it can happen if the wu is resumed incorrectly or abruptly crashes.
Look at the log to your gpu slot, you need to exit the client and restart
the wu from last checkpoint(client does this itself). The wu isn't actually
at 99,9%, If the last thing you see in the log is somewhere
between 0 - <99%.
if that's the case it's not actually doing anything, it can sit there for 10
or 16 hours for that matter, without doing any good.
pause the slot, restart the client and resume the slot again, if this isn't your issue.
You should look at the log either way to see if it gives you any hints, if it doesn't,
post the log here.
