so after going to the chemist today and asked for Isopropal alchol and they didnt stock it i woudl like to know if nail polish remover is a good substitute here is what i have
http://www.boots.com/en/Sally-Hansen-Strengthening-Nail-Polish-Remover_1255886/?cm_mmc=pla-_-google-_-PLAs-_-Boots+Shopping+-+Category+-+Seasonal
will this work?
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
https://linustechtips.com/topic/263176-help-need-to-know-if-this-will-work/
''Available in four variants: Moisturising with Vitamin E and Aloe Vera - for dry, brittle nails. Regular With Vitamin E and Apricot Extract - for all nail types. Strengthening With Vitamin E and hydrolysed wheat protein - for soft thin nails. Acetone Free With Vitamin E and Chamomile - for artificial and sensitive nails''
Lord Pantaloons, on 30 Nov 2014 - 7:32 PM, said: If Lawrence leaves his house and travels at a constant 40 MPH. How long will it take Bill from next door to shove a banana up his mom's rectum?
FX-6300Gigabyte R9 270X 4 GB OCWD Blue 1 TBCorsair Carbide 300RArctic Cooling Freezer 7 Pro rev. 2Silverstone Strider Essential 500WAsus M5A97 R2.0Dell P2314HYamaha HTR-5740Mordaunt-Short Avant 309iSuperlux HD-668 BCooler Master CM Storm Quickfire UltimateGigabyte M6900Oneplus One 64 GB
You can get alcohol from any store for around 99c ... Why bother with a chemist?
because its alot harder to get hold of in the UK i have been everywhere
}else{
the chemist recomended white spirites is this safe??
}else{
Amazon has it.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
Well that obviously depends on the use you want to give it, which you haven't mentioned.
If what you want is to polish the top of your CPU or GPU, then the answer is no: don't use nail polish remover! The acetone derivatives contained in it can damage your processor very badly.
i7 4790K || R9 290X + R9 290 || 16GB G.Skill TridentX 1866 || Gigabyte Z97MX Gaming 5 || Crucial MX100 256GB || WD Caviar Blue 1TB
Indeed it is, I got mine from Maplin although I understand there may not be one conveniently near where you live, I'd try a few more electronics/hardware stores if there are any locally and if all else fails order it online.
Thank you.
Wardojack.
Ended up a huge fluke we ordered syringes today and they came with isopropyl alcohol wipes
}else{
