hey Linus community I am building a new pc and my neighbour recommended that I show get a UPS. But I'm not sure how much power I need it to have to power my rig
Here's the rig
CPU
Intel core i7 5820k at 4.0ghz
Motherboard
Msi x99s sli plus
RAM
gskill ripjaws 4x4gb ram at 2400mhz
GPU
gigabyte wind force gtx980
Case
Corsair 780t red and black
Storage
1tb seagte barracuda, Samsung Evo 250gb
PSU
evga supernova 750w
Display(s)
samsung 28" 4k monitor
Cooling
corsair h100i/5 fans
Would this one be enough to power my rig for at least 2 mins?
http://www.pccasegear.com/index.php?main_page=product_info&products_id=17582&cPath=334
Thanks
Wolffangs147
Its when dragons have so much sex that the cpu cant handle it
https://linustechtips.com/topic/262958-ups-for-my-pc/
PC Partpicker puts your build at around 101W(idle) to 430W-450W (load) usage, and given the graph from the UPS you posted, you would have about 2 minutes under load. This doesn't include powering displays/peripherals, but I assume those would be rather negligible compared to your PC.
Keep in mind I don't have any first hand experience with UPS devices, just thought I'd send a reply.
CPU: i7-4790K --- HEATSINK: NZXT Kraken X61 --- MOBO: Asus Z97-A --- GPU: GTX 970 Strix --- RAM: 16GB ADATA XPG --- SSD: 512GB MX100 | 256GB BX200 HDD: 1TB WD Black --- PSU: EVGA SuperNova G2 --- CASE: NZXT H440 --- DISPLAY3 x Dell U2414H --- KEYBOARD: Pok3r (Clears) --- MOUSE: Logitech G Pro --- OS: Windows 10
https://linustechtips.com/topic/262958-ups-for-my-pc/#findComment-3577083
Could you post. That pcpartpicker link plz
Thanks
https://linustechtips.com/topic/262958-ups-for-my-pc/#findComment-3577119
Never used a Eaton UPS before, but I personally like APC. For your set up, the APC Back-UPS Pro 1300 would work pretty good, since it can supply the max "theoretical" of your system(assuming if your PC actually draws 750w). It give you some headroom as well, so you could have your monitor and probably a small lamp on it(so handy in black outs). Since your computer probably draws less than 500 watts, you could probably power your system for longer than 2 min and have some light in the dark for a while. If you do some more looking around, I would try to avoid Cyber Power(low quality, poor performance, those types of things).
http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=BR1300G&total_watts=200
https://linustechtips.com/topic/262958-ups-for-my-pc/#findComment-3577132
I've used EATON and now I'm currently using cyberpower.
The EATON ones I had were 600W capacity and the batteries lasted about 10 years (I'm still using them but just as a surge protector)
My current PC used over 600W on load so I had to get a different one.
The cyberpower one I have has an LCD that displays info about battery %, minutes remaining, voltage, total load (it's pretty handy and good to know)
Quality wise, I'm not too sure about the cyberpower. On paper, it has a slightly slower reaction time (in case of power surge, blackout) comparing to the EATON.
I've experienced a few blackouts, brownouts, and electrical surges during a storm with the cyberpower UPS and it's handled it well so far.
For the wattage, I suggest you get a 600W - 850W UPS, this way you can plug monitors, speakers etc along with your PC
Get around a 800W if you plan to put another GPU in your PC
    CPU: 3930k  @ stock                                  RAM: 32GB RipjawsZ @ 2133Mhz       Cooling: Custom Loop
MOBO: AsRock x79 Extreme9                      SSD: 240GB Vertex 3 (OS)                     Case: HAF XB                     LG 34um95 + Ergotron MX Arm Mount - Dual Review
  GPUs: Gigabyte GTX 670 SLI                     HDD: 1TB WD Black                                PSU: Corsair AX 860                               Beyerdynamic - Custom One Pro Review
https://linustechtips.com/topic/262958-ups-for-my-pc/#findComment-3577183
I need it to work with Australian plugs. Sorry :(
https://linustechtips.com/topic/262958-ups-for-my-pc/#findComment-3577213
I reckon I'll go with the 800w cause I will get a second gpu definitely
Thanks for your advice
https://linustechtips.com/topic/262958-ups-for-my-pc/#findComment-3577231
Would a 750w ups with 2 gpu's and a monitor be enough?
https://linustechtips.com/topic/262958-ups-for-my-pc/#findComment-3577275
Thanks
Here you go:  http://pcpartpicker.com/p/rqk7ZL
https://linustechtips.com/topic/262958-ups-for-my-pc/#findComment-3577337
Yeah should be plenty.
Your system will probably use up around 650W maybe more (depends on overclocking) with SLI
A 750W UPS will allow you to have some headroom for stuff like monitors.
Remember, If you're PC is somewhat idling and the power goes out, you'll have plenty of time to turn it off. (up to 40min or so battery time)
Maybe even leave it on until the power comes back on.
My UPS is a 900W and sometimes it says over 50 min of battery when my PC is idling. (when there is no power)
https://linustechtips.com/topic/262958-ups-for-my-pc/#findComment-3577741
Is that a cyber power one
https://linustechtips.com/topic/262958-ups-for-my-pc/#findComment-3577830
Yeah my current one is cyberpower, however you can go with whatever brand you want.
I've only had this one for about 2 years and so far so good.
Current version is the CyberPower VALUE1500ELCD
EATON is a good brand which I can confirm. (it may be a bit more expensive for the same wattage)
https://linustechtips.com/topic/262958-ups-for-my-pc/#findComment-3577869
