I have a i5 750 4GHZ 1.375V under a Megahalems. It idles at 50, starting stress test it gets to 75*C within 3 seconds and 80*C within 2 minutes. Ending stress test, it drops to 60*C within a second. Is it just the heatpipes working really well, or is this an indicator of bad thermal contact and I should reseat the heatsink?
Thanks.
https://linustechtips.com/topic/262332-cpu-rapid-temperature-fluctuations/
how are you monitoring your temps?
CPU: i7 4790k OC'd @ 4.6 ghz COOLER: Corsair H105 (SP 120mm Quiet Edition Fans) MOBO: ASRock Z97 Extreme 6 RAM: Kingston Hyper Fury 16GB (2x8) 1866mhz
SSD: Samsung 840 EVO 250GB HDD: WD Blue 1TB GPU: EVGA GTX 970 FTW 4GB PSU: EVGA Supernova G2 750w 80+ Gold Fully Modular CASE: Fractal Arc Midi R2
OPTICAL DRIVE: Samsung DVD Burner OS: Win 7 64bit   Please do some research of your own before asking questions. Google and Youtube are your friend.
The reaction in your chip is instant. This is not the temperature of the entire cpu but the temperature of the core.
This means it while eg. gaming can fluctuate 5-10 degrees. The drops you see are normal.
When in doubt: C4
Using hwmonitor.
What about 20 degrees, still normal?
Sure. I just did quick IBT test and while running it my temps went from 73C to 58C and back. Right after I stopped the test they dropped from 60C to 40C. Monitoring with RealTemp. So I'd say its more about software updating interval being one of reasons why drops seem to be so sudden.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
