Front Panel Audio NOT WORKING. HELP!
Solved by lani100,
I recently redid the cable management in my Corsair Air 540 and unplugged many of the internal headers in the process. When I put it all back together I noticed that the pc isn't recognising my earphones plugged into the front panel. I checked the mobo and the HD Audio header is securely connected.
What could be the possible cause of the problem and how do I fix it??
You might have actually pulled the cable on the jack connector.
