USB Extension Card Installation.
Go to solution Solved by TrueWhiteWolf,
try looking in your device manager and check if it comes up there if it does then go find the driver for it always good to check on the most basic processes (:
I've got myself a USB 3.0 extention card, and i've wired it all up to the mobo and card reader - but I'm not seeing my devices listed when I use the front (or back) usb ports attached to it. I've installed all the drivers but can't seem to find it. Where should I be looking for it? In computer->right click->manage? Or somewhere else?
https://linustechtips.com/topic/262124-usb-extension-card-installation/
If you attach a hard drive to the PC, does it show up? Probably a stupid question, but I can't really understand your question :P
PC Specs:
    • CPU
      Intel Pentium G3258 @ 4.0GHz
    • Motherboard
      Gigabyte GA-Z97X-SLI
    • RAM
      Corsair Vengeance 16GB 4x4GB DDR3 @ 1333MHz
    • GPU
      EVGA GeForce GTX 760 Superclocked ACX
    • Case
      Corsair Graphite 230T Red Windowed
    • Storage
      Western Digital Caviar Blue 500GB 7200RPM
    • PSU
      Antec HCG-620M
    • Display(s)
      Dell S2409W 1920x1080, HP vs19 1280x1024
    • Cooling
      Stock Coolers
    • Keyboard
      Microsoft Natural Ergonomic Keyboard 4000
    • Mouse
      Microsoft Arc Touch Mouse - Limited Edition Artist Series - Oh Joy
    • Sound
      Altec Lansing FX4021
    • Operating System
      Windows 10 Technical Preview
Gah. I knew it'd be in there. I must have either skimmed it or it required a re-installation of drivers.
