I only wanne cool my my CPU and later on my GPU but this is what i had in mind. I don't have any idea what fittings would be nice with my red colour build, but it has te be good quality.
Help me out and give me your thoughts.
My idea
CPU BLOK: Alphacool NexXxoS XP³ Light - Acetal Edition - Intel/AMD
Reservoir: Alphacool Cape Corp Coolplex Pro 15 LT
Pump: Alphacool VPP655 - G1/4 IG incl. Attachment
Radiator: Alphacool NexXxoS XT45 Full Copper 180mm Triple
Tube: Alphacool HardTube 13/10mm plexi clear 40cm
https://linustechtips.com/topic/261831-first-time-project/
If you want to do red and black.  I would get just black compression fittings from Swiftech or Bitspower.  Then get red UV coolant and clear tubing.  Along with some UV lights and you'd be set.  If you dont want to spend that much, just get black fittings, and red colored tubing.
Tohrchur
https://linustechtips.com/topic/261831-first-time-project/#findComment-3572102
