I have an i5 4670k with the stock cooler on it at the moment however I am looking to overclock it in the near future. Would something like the Hyper 212 Evo be fine or would I want something more expensive or maybe even a pre filled liquid cooler.
Any help would be greatly appreciated.
https://linustechtips.com/topic/261715-over-clocking-cooler/
212 is really good in price/perfomance ratio. I've clocked 4790K to 4.7GHz, 1.29V with it, max temps in OCCT staying under 85C which was my stopping point. Its impossible to say how much larger cooler like Dark Rock or some Noctua would affect on that. It depends more on CPU. Sure, you can get lower temps with water or bigger air coolers. But if you are on budget, 212 is best choice.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/261715-over-clocking-cooler/#findComment-3569426
If you want a budget cooler, you can't go wrong with the BeQuiet pure rock, it's the same price as the 212 but is newer and is likely to be better performing. If you want a larger cooler, the Noctua NH-U14S or BeQuiet dark rock 3 is the best choice, and if you want the best air cooling performance the Noctua NH-D14/15 is top dog, along with the Cryorig R1 ultimate.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/261715-over-clocking-cooler/#findComment-3569604
