need help with CPU choice
Go to solution Solved by SeanBond,
ether a R9 290 or GTX 970
Then get the i5.
Are you going to use a discrete graphics card? If so i5, it's not even close
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
Then get the i5.
