Sometimes when I play games my screen turns black, and I end up having to restart the computer.So I opened up one side of my computer case, but it still happens.I used msi Kombuster to test it the max temperature was 62 degrees.So it is probably not overheating.Are there any other reasons why this happens?
(GPU: GTX 550 ti cyclone 2)
https://linustechtips.com/topic/26115-overheating/
Does it happen with all games? Any overclocks on the card?
https://linustechtips.com/topic/26115-overheating/#findComment-332166
Please try reinstalling your drivers.
https://linustechtips.com/topic/26115-overheating/#findComment-332182
I am using the geforce experience and it says my drivers are up to date.Should I try reinstalling drivers?
Yes. Download the latest drivers(certified or beta), remove your current ones, and then install the downloaded ones with the clean install box checked off.
https://linustechtips.com/topic/26115-overheating/#findComment-332295
as said above.
-clean install of drivers
-try different drivers that are known to be highly stable 306.97 is one of those
-try a clean install of windows
-try bumping up voltage for graphics card
-try a different pci express slot
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/26115-overheating/#findComment-332367
Clean up the sink / radiator..
NZXT Lexa S - Asus M5A97 R2.0 - AMD FX 8150 @ 4.2 Ghz - Corsair H70 - Corsair Vengeance Pro 2133 Mhz 16 GBAsus GTX 970 4GB - Corsair CX 600 - Benq XL2420t - Samsung 840 Pro 256GB - WD Live 3TB - Razer Blackwidow Ultimate 2013 Keyboard - Razer Ouroboros Mouse - Steelseries QcK Sk Gaming Edition :wub:
https://linustechtips.com/topic/26115-overheating/#findComment-332537
