I am in India and i want to buy Max Payne 3 from Amazon.com (pc download version). my friend which is in US can buy it for me as it is for US customers only.
I want to know that what happens when he buy the game for me? Will it be added to my steam library and i can download or is there no way that i can download the game and play it?
Please reply immediately..
Thanks in advance
https://linustechtips.com/topic/261019-instant-help-needed/
Thanks in advance
I advise to buy it direct from Steam.
https://linustechtips.com/topic/261019-instant-help-needed/#findComment-3556778
Yes i agree to all of you.. I think that you are saying correct maybe i should buy it directly on stream it is only $2 costlier..
It's only a bit more and you can be sure you are getting the game without issues. I hope you have fast internet though as the game is a really big DL.
https://linustechtips.com/topic/261019-instant-help-needed/#findComment-3556886
No man internet here in India sucks like hell.. I have a 2mbps connection..
Every game that i buy takes ages to download.
https://linustechtips.com/topic/261019-instant-help-needed/#findComment-3556924
Thanks in advance
I use g2a.com Max payne complete edition is on there for %5.34 from the top seller. Sold 243 items and has %100 feedback. Some advise not to use g2a as you "may" not get a code. But it's just like ebay, buy of someone with good feedback and you're good to go. Also use shield to for an extra 80p.
I bought 18 items so far without a single problem and get the key in 5 minutes.
If i'm right then your currency is RUB which on g2a is 482.54. Not sure how expensive or cheap that is
I7 4790K-----ASUS Z97-A-----GTX 1080-----CORSAIR H105-----CORSAIR VENGEANCE PRO 16GB-----ASUS PG278Q-----LOGITECH G900-----MASTERKEYS PRO L-----Sennheiser GSX 1000
https://linustechtips.com/topic/261019-instant-help-needed/#findComment-3556967
Oh man that's terrible. I live in rural Canada and I get 6 down and 2 up. In the states Google is offering to some people free 5 megabits download and 2 megabits upload for free LOL all you need to do is give them $300 for installation fee.
https://linustechtips.com/topic/261019-instant-help-needed/#findComment-3556999
