Im looking for a build that costs 650$ canadian, but that includes monitor and keyboard. http://pcpartpicker.com/p/d3k9FT I have been looking at that buid. Anyhing that could be improved on it? Also would be gratefull to get monitor recomendations, and keyboard recomendations.
https://linustechtips.com/topic/260964-need-help-with-a-build/
looking good although I would suggest getting a better CPU and pulling back to maybe a 270 for your GPU
Please use http://pcpartpicker.com/ for everybodones sake!
and quote me if you want me to see a reply please :)
pewpewpewphysicslazers!!!
https://linustechtips.com/topic/260964-need-help-with-a-build/#findComment-3556177
Intel doesn't offer the best low end CPU's I'd recommend getting something from the red team. Either an FX4300 or FX6300 would be a better choice in this price point.
My System Specs: (Short list) i7 4770k, GTX 780, many SSD's, a 2 TB HDD(deceased :( ), Corsair 650D. Full list: http://pcpartpicker.com/user/kchriz6097/saved/8dh7YJ
Upgrade Plan: Acquire some Black Noctuas then add 16 or 32GB of 2133MHz memory
https://linustechtips.com/topic/260964-need-help-with-a-build/#findComment-3556178
