5930K Cooling.
Go to solution Solved by Katsu-K1L,
Easter Europe ( I`m buying from http://www.overclockers.co.uk/index.php )
Up to 100-150 Pounds.
http://www.overclockers.co.uk/showproduct.php?prodid=HS-026-NC
in my opinion this a really good aircooler but idk if it will fit with certain ram sticks if it doesn't check this
http://www.overclockers.co.uk/showproduct.php?prodid=HS-004-NX
My PC
[ I5 4690k (no oc) - Gigabyte Z97 D3H - 8GB Ram - Sapphire R9 280X Vapor-X ]
https://linustechtips.com/topic/260857-5930k-cooling/#findComment-3554917
TY I`m using Corsair Vengeance RAM (BTW)
https://linustechtips.com/topic/260857-5930k-cooling/#findComment-3554936
