Hello, I recently purchased a WD Blue 1TB HDD for a friends build, and its been having a lot of problems. Yesterday when I tried to install windows, it ended up freezing before it could get to the hard drive section. Then when I tried plugging it into my main computer, it doesn't show up in the disk management (but does show up in device manager). It spins like normal, and looks/sounds like it should.
So I ended up using an older 500GB WD Green drive to install windows on and it worked fine. I still need it to work, so is there anything else I can try to do to format it before I have to RMA it? Would it be possible to install a linux distro on it to format it (I tried Ubuntu, and that doesn't work either).
Thanks!
The Grey Squirrel
CPU: i7-6700k @ 4.8GHz - CPU Cooler: Be Quiet! Dark Rock 3 - Motherboard: ASUS Z170-E - GPU:  ASUS GTX 1060 DUAL
Case: Inwin 303 - RAM: 4x8GB Corsair LPX Storage: 2x Samsung 850 EVO 500GB - PSU: EVGA SuperNOVA G2 550W
Mouse: Logitech G502 Wired / Bungee Keyboard: Corsair Strafe Cherry MX Red Headphone: Sony MDR- 1R
Microphone:  Blue Yeti - Webcam: Logitech C920 - Monitors: 3x Dell S2415H
https://linustechtips.com/topic/260848-hard-drive-not-working/
RMA it. It's dead
Hm, do you think it would be quicker to order another one (while its on sale) and request a refund?
The Grey Squirrel
https://linustechtips.com/topic/260848-hard-drive-not-working/#findComment-3554819
Agreed.
Don't you think it could be on sale because it's part of a bad batch?
Well, it wasn't on sale. I just picked it up because I had a good discount if the price was over 100 (25 dollars off).
The Grey Squirrel
https://linustechtips.com/topic/260848-hard-drive-not-working/#findComment-3554842
Hey Dubesta11!
I'm sorry to hear that but apparently your drive is dead or dying, just as the others noted.
In my opinion, you'd be better off RMA-ing it and not paying for another drive. This is the link for the RMA process:
http://wdsupport.wdc.com/rdsfdc.asp?linktype=rmacreate&portaltype=wd&custtype=end&fs=&ss=〈=en
Good luck, hope the next drive works great!
CK_WD
If you think I helped, like!  :P
www.wdc.com
https://linustechtips.com/topic/260848-hard-drive-not-working/#findComment-3561267
