Today I encountered the very first blue screen since 13 months, I have attached the event log in the file. What could be the cause for it? It happened when the pc was in idle. My first thoughts would go for the PSU- but right after rebooting the system I stressed the cpu, gpu and ram- nothing has occurred. What could be the cause for this blue screen? Is it the menace for something greater, like possibly PSU fail in a short future? Or, since it never happened before, was just an accident? Thanks for all responses and help!
post-154615-0-91361500-1417354791_thumb.
https://linustechtips.com/topic/260846-power-kernel-41-63-cause/
Just ignore it for now. If it persists, you might want to do something about it.
The kernel is the 'base software' (I can't think of a better term), so it probably has nothing to do with power (because software and hardware errors simply don't mix as far as I'm aware).
It seems like quite an old error so try running some updates. I don't really know what else to say about it. Also, 13 months without a bluescreen is awesome.
It might be caused by running certain applications together, but I don't see how that would happen:
Sig under construction.
https://linustechtips.com/topic/260846-power-kernel-41-63-cause/#findComment-3554808
