Hi!
I'm deciding between the 750ti, r9 270 dueal-x oc-lite and the 270x oc boost. I don't know which to choose, neither do I know for what company should I look for for those gpus.
Recommendations will be much appreciatet.
Longboarders/ skaters message me!
https://linustechtips.com/topic/260783-need-help-choosing-gpu/
r9 270x is most powerful, but it costs about as much as r9 280 which rolls over it. r9 270 is one of the best price/performance ratios. 750ti is very efficient.
https://linustechtips.com/topic/260783-need-help-choosing-gpu/#findComment-3554139
In my country the 270x is about 25EUR cheaper and I'm already waaay over my budget and the gpu is the only thing I can cut some corners without too big performance drop. What about the 270x vs the 270? They are roughly about the same price.
Whats your budget?
About 170EUR
https://linustechtips.com/topic/260783-need-help-choosing-gpu/#findComment-3554240
get the 270X, any brands would be good these are not very hot GPU,s they will all perform relatively the same...i'd go with sapphire if possible but get the cheapest 270X available to you really.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/260783-need-help-choosing-gpu/#findComment-3555681
If you can afford the r270x, go for it but if you are at a price range with n750ti a r265 would be better.
The blood on to your heart start pumping faster when you notice me.
But is ok.
Judge me for my nickname, my avatar and for the low amounts of posts I have. I will keep your heart beat raised.
https://linustechtips.com/topic/260783-need-help-choosing-gpu/#findComment-3568243
