Hello, I was wondering why is my PC case getting hot even at below 50% CPU load. My PC is cleaned of dust, and at max load my CPU is running at 60°C. Like part where is located PSU is cold, the GPU is cold, but where is the CPU on the other side (Behind cpu, behind mobo side) is getting hot.
Using fx4100 at stock speeds and stock cooler, hd6770 gpu at stock speeds (60 is max on overload games), 4gb hyper x blu 1600 ram and 500GB hdd. Like I got friend with i5 2500k but his cpu is running at 80C and his case is cold...
Hoe Hoe Hoe and a bottle of RAM © Gankplank
https://linustechtips.com/topic/26056-pc-case-is-hot/
Re-seat the heatsink and re-apply thermal paste. That usually fixes things like this imo.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/26056-pc-case-is-hot/#findComment-331219
To keep your case cooler you need to have a case with good ventilation and fans to move the hot air out of the case.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/26056-pc-case-is-hot/#findComment-331221
I have none . . . Got behind 2 holes for 80 mm fans I think, and 140mm in front and 2x 120mm at the side. They aren't populated :D
https://linustechtips.com/topic/26056-pc-case-is-hot/#findComment-331227
lolrly?
*facepalm*
https://linustechtips.com/topic/26056-pc-case-is-hot/#findComment-331249
