How do you watch current seasons of Shows without cable?
Read the LTT Beginner's Guide; it's like a guide on how to not be a moron
 CPU: i5-4690k 4.1 GHz CPU Cooler: Cooler Master 212 EVO GPU: Asus Gtx 970 Strix MOBO: ASUS Z97-E RAM: Crucial Ballistix Sport 16GB (2 x 8GB) 1600 SSD: Samsung 840 Evo 500GB HDD: Seagate Barracuda 1TB PSU: Cooler Master 600W 80+ Bronze Case: Cooler Master Storm Scout 2 Advanced
https://linustechtips.com/topic/260518-watching-current-tv-without-cable/
Netflix??
My Current Build:
Intel i5 3570K @ 4.4GHz 1.11V, Cooler Master Hyper 212 EVO, Asrock Z77 Extreme4, Corsair Vengeance 8GB 1600MHz, Samsung 840 EVO 250GB, Asus GTX 760 DCII Overclocked, Corsair CX600M
Netflix??
Netflix doesn't have current shows.
It sounds like you need hulu or (find these at wallmart or somewhere on the internet) a USB tongle that gives you access to all your local chanels and some popular others.
Obligatory PC specs
CPU: Intel Core i5-6600K 3.5GHz
CPU Cooler: Corsair H50
Motherboard: Asus Z170-E ATX LGA1151
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB)
Storage: ADATA Premier SP550 240GB
Storage: Western Digital Blue 500GB
Storage: Western Digital BLACK SERIES 1TB
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB G1
Case: Fractal Design Define S
Power Supply: Corsair CSM 550W
If you are new please read the CoC!
 Please FOLLOW YOUR OWN THREADS!
 Quote people when replying to them.
PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR DARK THEME USERS.
 Mark your problem as solved if answered and like all helpful information.
 DO NOT QUOTE IMAGES(!) just type -pic- or tag them as spoiler.
Don't criticize people for asking "stupid question".
There is actually a hidden search feature on the forums here: Search
IT DOESN'T MATTER IF YOU'RE A FANBOY/FANGIRL. WHAT MATTERS IS THAT YOU DON'T LET THAT EFFECT YOUR HARDWARE RECOMMENDATIONS.
DO NOT POST SPAM!
I tried going on Hulu and none of the shows had the current season.
I google them and watch them online.
You mean on their website or Google play.
Idk. If i want to watch say sherlock holmes season 2 episode 2, i google "sherlock holmes season 2 episode 2 watch online" and voila, i can watch it (eg http://watchseries.ag/episode/sherlock_s2_e2.html).
Samung Tab S 8.4
  • 5 weeks later...
You can watch shows live at TVCatchup.com (the channels on TVCatchup.com are the ones you will find on Freeview). Also, most TV Channels stream their channels on the internet. For example, Channel 4 has their 4oD (4 on Demand) service which allows you to watch the channel live and watch episodes of shows on 4oD after they have aired. You can also look into subscriptions for Netflix, Blinkbox and Amazon Instant Video. Hulu also has a bunch of new shows, you can even support Linus Tech Tips by using their affiliate link. Also, if you connect a TV Tuner to your computer, you can use your computer as if it were a TV by connecting your aerial to the TV Tuner connected to your computer, this will allow you to watch free-to-air channels on your computer (you could connect this to your HTPC, desktop or laptop).
Hope this helps. :)
"Have you tried turning it off and on again?"
Code of Conduct ■ Suggestions ■ Report a Bug ■ FAQ with Windspeed36 ■ Useful Links ■ Memes
