"Splinter Cell" Blacklist_game.exe stop working. Help
Go to solution Solved by Rusty.,
Took the game off my HDD and and installed it to my SSD and now it's working.  I dont have an option for SLI??   It runs good on 1 card @ 120fps or so but vsync looks choppy... I hate the tearing but I guess I'll just have to deal.  It's odd that with the game installed on my 2nd drive it played super smooth in SLI with vsync on and now I cant use SLI, vsync is crap, but it doesn't crash...  ???  I wish I knew what the hell...
Got it from Steam
Playing in DX11 now and it is working.
Thanks.
I've played about 3 missions with few issues in DX9 mode. Trying to play Grim's mission I get
Faulting application name: Blacklist_game.exe, version: 0.0.0.0, time stamp: 0x5245f416
Faulting module name: Blacklist_game.exe, version: 0.0.0.0, time stamp: 0x5245f416
Exception code: 0xc0000005
Fault offset: 0x003ccf0b
Faulting process id: 0x834
Faulting application start time: 0x01d00c21d77162cf
Faulting application path: E:\SteamLibrary\steamapps\common\Tom Clancy's Splinter Cell Blacklist\src\SYSTEM\Blacklist_game.exe
Faulting module path: E:\SteamLibrary\steamapps\common\Tom Clancy's Splinter Cell Blacklist\src\SYSTEM\Blacklist_game.exe
Report Id: 422a0573-7815-11e4-b7e0-d850e64a665e
Does anyone know what I should do? This is 2 uplay games that I paid for that don't work. unacceptable  ... I've tried changing the "WindowStyleFinal=2" and tried DX9 and 11. Tried disabling my 2nd GPU Nothing works crashes on the loading screen.
I7 4770 k
gtx 670 @ 2
New drivers for gpu
Thanks in advance
Might be a software issue,I played in DX9 on my GTX 260 and still rocks,no problem at all.(Including Multiplayer,Co-ops)
Did you bought it directly from Uplay or Steam,I've heard some player said they bought on steam and have launch issue...though it should be patched out in 1.3 version...
ubisoft..((cough...
Anyway,try to re-install it,I really don't think this is a hardware issue...
Got it from Steam
Thanks.
Got it from Steam
Thanks.
Glad to see you solved,but this game is SLI certified by Nvidia,should be no problem play with SLI,but I don't recommend to turn on the Vsync...SLI with Vsync might tearing if your pc can't hold certain level frame rate.
Best bet,turn on SLI only and leave the vsync alone...don't locking your frame rate or anything else...should be no tearing...
