Small Problem...
The Appdata is what is crashing my pc, it fills up and then crashed the SSD as it becomes full, I have just been sent a new Seagate 2Tb SSHD, I was thinking of doing a full reinstall of my pc and installing windows to the SSHD and just putting a few programs I use a lot onto the SSD (A few steam gamesand Adobe AE) I doubt steam games would work on a separate drive as they're dependant on the SteamApps folder (Possibly replicate and do an install of steam on both drives?)
I'll install the 2tb SSHD tonight when I get home, I had ordered it with my new build but came faulty, just got it replaced, As far as i've heard I could just use the SSD to run a few programs that I need to run smoothly.
Also heard that win7 will work just as fast the on SSHD as it would on the SSD..
Thanks for the help
I had an SSHD and I just moved to an SSD, there is no doubt that the SSD is far better. You can move your entire AppData folder to your SSHD using the method I described and it will still function perfectly. You need to move all of the folders in "AppData" individually, but you can move "Roaming", "Local", and "LocalLow" onto your SSHD. I highly recommend you do this and keep your SSD as the boot drive, you would miss the performance if you didn't.
As for Steam games, you can reinstall Steam into a folder on your SSD (just go through the install again and set it to install in "D:\Steam" or whatever you call your Steam folder). You can then copy the Common folder from SteamApps and reinstall your games without downoading them again.
This is by far the best solution and you can definitely resolve your problem easily. Feel free to ask here if you need any more help with this process, best of luck ![]()
