ok guys to cut this short i bought a pc case with a motherboard first ever build pc i did not get any standoffs with my case so i screwed my motherboard  to the case without stand-offs and left it overnight then i watched a video of someone putting in standoffs ''note'' i did not yet build my pc fully yet so i rushed to my pc and got my motherboard out of my case haven't tested it can't test it yet help is it broken or am i jsut being paranoid?
CPU: intel i7 4770k 4,1GHZ stock cooler  RAM: 8GB Ripjaws G-Skill8-GB-DDR3-1600 (2x 4gb)  GPU: GTX 760 Msi dual fan PSU: corsair cx 750 WATT modular MBoard: gigabyte-ga-z87-d3h  HDD: WD Caviar black 1tb  SSD: samsung  850 evo 250gb  Keyboard: Corsair K70 MX Cherry Red Mouse: Corsair M90 Headset: Gamecom 780 OS: Windows 7 X64
https://linustechtips.com/topic/26038-problem-solved-i-guess/
No. It's probably not broken. Put the standoffs in when you get them and put the motherboard back in to verify though.
https://linustechtips.com/topic/26038-problem-solved-i-guess/#findComment-330985
If you've not ran the system, it'll be fine.
If you have, you'd know something was up the second it refused to POST.
Standoffs man, use 'em
"You know I was taught that if you don't have anything nice to say, don't say anything at all. You feeling me cocksucker?"
"Ethernet is internet juice. You have to press the internet really hard and you will get it."
"My quantum milk machine brings every boy to all the yards." non futuis et sursum
PC Specs! | I7-950 | 24GB RAM | 10TB Storage | GTX 970 Strix and a 560TI DCUII for Physx | 120GB 840 + 250GB 850 EVO | Asus xonar DGX
Please take a moment to look over the forum CoC here.
https://linustechtips.com/topic/26038-problem-solved-i-guess/#findComment-330994
If you havent turned the pc on u should be fine.
Intel i5 4670k @4.5 | 16GB Patiot Viper Xtreme | Corsair H100i | MSI Z87 GD65 | Crossfire x2 Asus 7950 Direct CUII
250GB OCZ SSD | LG Bluray RW Drive | 750Watt PSU | Corsair 450D | Corsair K50 | Corsair M40
https://linustechtips.com/topic/26038-problem-solved-i-guess/#findComment-330998
Language, kiddo.
Also, you're probably fine, if it hasn't been powered on there's no reason for anything to have gone seriously wrong.
I would suggest reading manuals before proceeding, they're helpful when you're learning, prevent expensive mistakes.
- Silverstone TJ08B-E - Gigabyte Z87M-D3H - i7 4770k @ 4.0GHZ 1.2v - 16gb Kingston HyperX Black 1600 - Gigabyte GTX 770 OC 4GB -
- Silverstone Fortress FT02 - MSI Z77 Mpower - i5 3570k @ 4.0GHZ 1.09v - 8gb Mushkin Blackline 1600 - MSI GTX 670 PE -
- Lenovo T430 (1600x900) - i5 3210m - 8GB DDR3 1333 - nVidia NVS5400M - 256GB mSATA OS - 320GB HDD-
https://linustechtips.com/topic/26038-problem-solved-i-guess/#findComment-330999
i bought standoffs since the store i bought it from said i prolly took it and asked for me fucking stupid i know but i put them on it back in the case still awaiting my new ram and psu
https://linustechtips.com/topic/26038-problem-solved-i-guess/#findComment-331000
sorry for the language i'm jsut concerned already spend about 600-700 euros that's why not just the motherboard
https://linustechtips.com/topic/26038-problem-solved-i-guess/#findComment-331005
U will be ok. If on the tiny chance its not, just RMA it :P DOA lol. But tbh i would say ur 99% fine. Ive had a secondary mb running just on a table as a folding machine for a while.
https://linustechtips.com/topic/26038-problem-solved-i-guess/#findComment-331012
thanks for the big help now i can finally sleep
https://linustechtips.com/topic/26038-problem-solved-i-guess/#findComment-331018
I would edit ur original post typo'ish?  as NewAndreas quotes :P
https://linustechtips.com/topic/26038-problem-solved-i-guess/#findComment-331030
