AX760 power supply buzzing
Solved by Aniallation,
i'm pretty sure that its not my video card, and im way under total power usage (gtx 760 evga and FX-6100 amd). my power supply buzzes, but when i launch a heavy game or kombustor, it stops. so only under a load does it not make a sound. what do i do? i've only had this power supply for two years and would like to avoid an RMA or another purchase. again, what do i do?
It's choil whine. The AX PSUs are notorious for it and it's not a defect that will be covered under warranty, so they will not RMA it.
