pc wont start help
Go to solution Solved by JamesYang,
Ok Tried Old PSU which is just 300w. turned on psu without connecting to motherboard light turns on. connected to Motherboard no light on psu or case. not sure if i put wires wrong. All parts are new.
Either you've got a faulty motherboard or you connected the cables wrong,but I doubt it,considered the power cables only fit in one way..so...or you could connected the case's power button wrong.
Better calm down and double checking your cables connectors make sure they all goes in the right place and direction.Cheers.
Building new pc. all of them are new except for HDD  from Old PC that wont turn on for some reason.
There is No light, no fan running. nothing. took graphic card out, HDD. still nothing.
CPU - AMD FX6300 Black Edition 6 Core
Motherboard - Gigabyte GA-970A-DS3P
RAM- Crucial Ballistix BLS2C4G3D169DS3CEU Sport XT 8GB (4GBx 2)
Graphic card - MSI GTX 750 Ti 2GB GDDR5
pc case -Zinc 200 PC Gaming Case.
PSU - EVGA 500W PC Power Supply - White
https://linustechtips.com/topic/260163-pc-wont-start-help/
are there any lights on the mother board lit up?
CPU: i7 8700k Motherboard: MSI Z370 Krait Gaming RAM: 4x 8GB Corsair Vengeance Pro (2 white, 2 black) GPU: MSI RTX 2070 Armor Case: Corsair Crystal 570x White HDD: 2x 2TB Seagate Barracuda 7200rpm Sata 3 SSD: 240GB Corsair Force 3 + 500GB Samsung 970 Evo Cooling: Corsair Hydro Series™ H150i PSU: Corsair RM750i OS: Windows 10 Pro 64-Bit
Mouse: Logitech G600 Keyboard: Corsair K95 RGB Cherry MX Brown Monitor: Samsung S24C570L 1080p 23.6" + AOC AGON 240Hz 1080p Sound: HyperX Cloud Headset Black/Red + Logitech Z213 Speakers 2.1
https://linustechtips.com/topic/260163-pc-wont-start-help/#findComment-3547675
Did you flip the switch on the back of the power supply?
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/260163-pc-wont-start-help/#findComment-3547702
turned power on and off several times. psu doesn't have light
if there are no lights at all either the PSU is broken or the psu cable isnt working. whatever it is, it's a power issue.
https://linustechtips.com/topic/260163-pc-wont-start-help/#findComment-3547817
https://linustechtips.com/topic/260163-pc-wont-start-help/#findComment-3547852
https://linustechtips.com/topic/260163-pc-wont-start-help/#findComment-3548061
unplug the cases power button cable from the mobo and touch the 2 pins with a screwdriver
CPU: i7 4790k OC'd @ 4.6 ghz COOLER: Corsair H105 (SP 120mm Quiet Edition Fans) MOBO: ASRock Z97 Extreme 6 RAM: Kingston Hyper Fury 16GB (2x8) 1866mhz
SSD: Samsung 840 EVO 250GB HDD: WD Blue 1TB GPU: EVGA GTX 970 FTW 4GB PSU: EVGA Supernova G2 750w 80+ Gold Fully Modular CASE: Fractal Arc Midi R2
OPTICAL DRIVE: Samsung DVD Burner OS: Win 7 64bit   Please do some research of your own before asking questions. Google and Youtube are your friend.
https://linustechtips.com/topic/260163-pc-wont-start-help/#findComment-3550231
didnt press power wire properly all good now thanks
https://linustechtips.com/topic/260163-pc-wont-start-help/#findComment-3550304
