Front USB 3.0 Problems
My front USB will work with some Mobos and not others. and My cases USB 3.0 will only work with some mobo even if they support USB 3.  Any ideas why this is?
what case are you using, also which motherboards did you try it on??
I5 4670k (Noctua NH U12S), Asus Maximus VI Hero, Nvidia GTX 560 ti Asus DCU II, 8GB Corsair Vengeance Pro, Kingston SSDNow v300 120 gb SSD 1TB Seagate Baracuda, Corsair Carbide 300R
I like pie
https://linustechtips.com/topic/259901-front-usb-30-problems/#findComment-3545134
Though...you can use a USB 3.0 to USB 2.0 adapter...down side its speed will downgrade to usb 2.0 but the ports will work...that's what I done to my C70 case...
since the front usb 3.0 just won't work on my X79-UP4 motherboard,and I've rmaed two times still won't work..so..yeah...
https://linustechtips.com/topic/259901-front-usb-30-problems/#findComment-3545883
