This is my first build but i do not know if the parts will work.
AMD Athlon X4 860K 3.7GHz Quad-Core Processor
Corsair H100i 77.0 CFM Liquid CPU Cooler
ASRock FM2A88X-ITX+ Mini ITX FM2+ Motherboard
Mushkin Blackline 16GB (2 x 8GB) DDR3-1600 Memory
Corsair Force LS 120GB 2.5" Solid State Drive
Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Corsair 250D Mini ITX Tower Case
Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply
I already have a r9 270 but i could sell it or use it in another build
If these parts are incompatible or someone has a better idea for a gaming build for 700$ or less please reply.  Thanks in Advance!
https://linustechtips.com/topic/259749-first-build-help-and-recommendations/
Here is a nice budget build just toss in your R9 270
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor  ($69.99 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($26.99 @ NCIX US)
Motherboard: ASRock FM2A88M EXTREME4+ Micro ATX FM2+ Motherboard  ($71.74 @ SuperBiiz)
Memory: Patriot Signature 8GB (1 x 8GB) DDR3-1600 Memory  ($69.29 @ Amazon)
Storage: Crucial M500 120GB 2.5" Solid State Drive  ($71.99 @ B&H)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($24.99 @ NCIX US)
Optical Drive: LG GH24NSB0 DVD/CD Writer  ($15.97 @ NCIX US)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($84.15 @ SuperBiiz)
Total: $515.09
Generated by PCPartPicker 2014-11-28 18:03 EST-0500
Also if you have a TV with HDMI you can just plug the HDMI cord into the gpu to your TV
Changed the mobo to something better
Edited by Ramamataz
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
Perhaps?
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($209.99 @ Newegg)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  ($80.79 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1866 Memory  ($121.99 @ Newegg)
Storage: A-Data Premier Pro SP600 128GB 2.5" Solid State Drive  ($49.99 @ Newegg)
Video Card: EVGA GeForce GTX 750 Ti 2GB FTW ACX Video Card  ($109.99 @ Newegg)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($49.99 @ NCIX US)
Total: $714.71
Generated by PCPartPicker 2014-11-28 18:06 EST-0500
First off, If you only are gaming and watching youtube and not having more than 16-28 tabs at the same time you wont have much use for 16 GB RAM.
I think you should go with this, This is almost Twice the CPU performance in games And if you feel like it you can overclock.
It is a close to pure black theme so it will go with almost anything.
But this is in a ATX formfactor, If you want a m-ITX formfactor you would be better off with intel.
CPU: AMD FX-8320 3.5GHz 8-Core Processor  ($99.99 @ Amazon)
Motherboard: Gigabyte GA-970A-UD3P ATX AM3+ Motherboard  ($59.99 @ Newegg)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($84.99 @ Amazon)
Storage: Western Digital WD Blue 1TB 2.5" 5400RPM Internal Hard Drive  ($59.99 @ Amazon)
Case: Cooler Master Elite 431 Plus (Black) ATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($33.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($86.42 @ OutletPC)
Total: $527.34
Generated by PCPartPicker 2014-11-28 18:11 EST-0500
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
ok so looking at all the recommendations there are i made a new build
Base Price Promo Shipping Tax Price Where       CPU
f6776a85afe4c2236d84eb42fe6da169.thumb.j
$209.99   FREE   $209.99 Newegg
Remove
Combo discount automatically applied. (View details.)
    CPU Cooler
ddea57de9797549e80d05fb3acb2e83d.thumb.j
$29.99   prime.gif   $29.99 Amazon
Remove
Buy
Motherboard
b0778a7579d7989cf61cba22c9b589bc.thumb.j
$114.99 -$15.00 FREE   $99.99 Newegg
Remove
$15.00 mail-in rebate
    Memory
21a7efa482e84b9816372b03597208ce.thumb.j
$124.99   FREE   $124.99 Newegg
Remove
Buy
    Add Additional Memory                   Storage
cfae225dd3e43bf766ab1468189a4703.thumb.j
$49.99   FREE   $49.99 Newegg
Remove
Buy
    Add Additional Storage                   Video Card
566c5ee49cfcbaab340510c9084a06d4.thumb.j
$159.99 -$20.00 FREE   $139.99 Newegg
Remove
Buy
$20.00 mail-in rebate
        Add Another Video Card For 2-Way CrossFire                   Case
7a827d37f8b2deec68784d17a77b6fc5.thumb.j
$44.99 -$15.00 FREE   $29.99 Newegg
Remove
Buy
    Power Supply
765ccad5a9a96009c0c353cb44ab3405.thumb.j
$64.99 -$20.00 FREE   $44.99 Newegg
Remove
