okay guys, i need a 750 Watt reliable power supply in the region or under £65. it needs to fit in my nzxt h440 and HAS to be modular.
thanks in advance
~James
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
https://linustechtips.com/topic/259665-750w-power-supply-needed/
thanks in advance
~James
I can almost guarantee you that you don't need that much wattage but hey, here you go. http://pcpartpicker.com/part/evga-power-supply-120g10750xr
https://linustechtips.com/topic/259665-750w-power-supply-needed/#findComment-3543144
i ened up buying a corsair cs750m
This is £66.50 and is semi modular.
http://www.amazon.co.uk/dp/B008O50WGA/?tag=pcp0f-21
}else{
https://linustechtips.com/topic/259665-750w-power-supply-needed/#findComment-3543417
evga supernova g2  750w....one of the bst psu's you can buy
CPU: i7 4790k OC'd @ 4.6 ghz COOLER: Corsair H105 (SP 120mm Quiet Edition Fans) MOBO: ASRock Z97 Extreme 6 RAM: Kingston Hyper Fury 16GB (2x8) 1866mhz
SSD: Samsung 840 EVO 250GB HDD: WD Blue 1TB GPU: EVGA GTX 970 FTW 4GB PSU: EVGA Supernova G2 750w 80+ Gold Fully Modular CASE: Fractal Arc Midi R2
OPTICAL DRIVE: Samsung DVD Burner OS: Win 7 64bit   Please do some research of your own before asking questions. Google and Youtube are your friend.
https://linustechtips.com/topic/259665-750w-power-supply-needed/#findComment-3547530
