Quick question about two different GPU's running together.
As long as they have the same chip, and same amount of VRAM, it's k.
Those cards should work
Specs: 4790k | Asus Z-97 Pro Wifi | MX100 512GB SSD | NZXT H440 Plastidipped Black | Dark Rock 3 CPU Cooler | MSI 290x Lightning | EVGA 850 G2 | 3x Noctua Industrial NF-F12's
Bought a powermac G5, expect a mod log sometime in 2015
Corsair is overrated, and Anime is ruined by the people who watch it
It should work fine, I would SLI them tho
Intel 4670K /w TT water 2.0 performer, GTX 1070FE, Gigabyte Z87X-DH3, Corsair HX750, 16GB Mushkin 1333mhz, Fractal R4 Windowed, Varmilo mint TKL, Logitech m310, HP Pavilion 23bw, Logitech 2.1 Speakers
the manufacturer doesn't matter the least bit, but it has to be the same model like GTX 760 for red and green teams, and has to have the same amount of ram on nvidia cards, on AMD cards the ram will just lower itself to the lowest card like if I have a 4 gig card and a 2 gig card, the 4 gig card will lower itself to a 2 gig card.
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
