Cheapest HD800 Replacement Cable
I am looking for the cheapest functional HD800 replacement cable. Preferably 3.5mm and less than 3 feet long. Currently the cheapest I can find is $150 from Headphone Lounge. Sennheiser sells them for a stupid $200. I believe the connector is proprietary. I am not looking to DIY. And god damn, why can't more people sell shorter cables? I'm not using it to tie hostages up or something.
Plz halp save my audio feelz. I wanna catch all the qualities.
Thanks.
Ideas:
http://headphonelounge.com/headphone-cables/    ($157?)   Is it $100 or $150 and am I retarded?
http://www.aliexpress.com/item/6-5mm-3-5mm-Pure-99-777-8n-OCC-Cable-For-Sennheiser-HD800-Headphone-Earphone-LN004078/32234858791.html     ($90?)   Looks great but sketchy site and sketchy seller with no feedback. iScared.
http://www.ebay.com/itm/8-cores-Flat-braid-Silver-plated-Headphone-Upgrade-Cable-For-SENNHEISER-HD800-/121424985584?pt=UK_MusicalInstr_Access_RL&var=&hash=item1c457e3df0    ($96) A little bulky and too long.
http://www.amazon.com/copper-Silver-upgrade-Sennheiser-headphones/dp/B00MT4TSWQ/ref=sr_1_10?s=electronics&ie=UTF8&qid=1417169049&sr=1-10&keywords=hd800+cable   ($91)   Ehhh. Looks kindda derpy. But if that's what I gotta go for, so be it.
In Placebo We Trust - Resident Obnoxious Objective Fangirl (R.O.O.F) - Your Eyes Cannot Hear
Haswell Overclocking Guide | Skylake Overclocking GuideCan my amp power my headphones?
https://linustechtips.com/topic/259281-cheapest-hd800-replacement-cable/
the connectors are $40 alone, good luck finding a cheap cable.
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
Thanks.
Ideas:
Did you try http://www.bestintheversecables.com/ ?
Also, the ones from headphonelounge, take whatever price you're looking at, and add $50.
I actually talked to the guy that owns headphonelounge a while back, he'll help you with everything etc.  You can call him basically whenever or email him, he'll help you do everything you need etc.
I was going to buy a cable for my LCD-2's a while back and was talking to him about it, he explained a lot of stuff etc. Pretty nice guy, won't try to snake oil you either.
