can someone go through what dye is the best and how much?.
i havent seen any video for it so i dont understand.
im going for a pump and a res 250ml and cpu block and later on a gpu block
i think im going for clear tubing and dye in water (light blue) so i was wondering how to blend and so on.
Thank You for the help :)
https://linustechtips.com/topic/258901-dye-help/
Try to avoid all of them... Red is worst but others are not far behind. Best is to use color tubing.
^This
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/258901-dye-help/#findComment-3535699
