Hey guys! So I am making a build for christmas, and it will be my first one! It will be a gaming one.
I need some advice on what motherboard to get. This is my build. http://pcpartpicker.com/user/Boston_Bruins_SD/saved/jhLbt6
Also, any criticism on the built its self please tell me!
https://linustechtips.com/topic/258599-need-help-with-build/
Get the G55 SLI. I would recommend to change that mouse to another one. the Ouroboros can be an alternative to that.
My Current PC Codename: Scrapper
Intel i5-3570 | Some LGA 1155 MOBO Some Generic DDR3 8GB 1600Mhz | PowerColor RX 560 2GB | Recycled HP Case Crucial MX100 128GB 1TB WD Blue 7200RPM | Some Generic 500w PSU | Intel Stock Cooler
https://linustechtips.com/topic/258599-need-help-with-build/#findComment-3532519
Do you recommend changing the mouse because of the high price tag?
Oh, also, a pair of headphones/headset. I have a Blue Snowball mic right now. would you recommend I get a pair of like Sennheisers or a gaming headset?
https://linustechtips.com/topic/258599-need-help-with-build/#findComment-3532526
Get the Sennheiser HD 558 or the ATH-M50. The most recent AKG K7XX is also a great headphones based on Linus' review. If you can, try to take a look and test it first before choosing what to buy. The problem with the mouse is that I read some of the reviews that the sensor easily dies. The ouroboros isn't the most accurate mouse, but it can be both wired or wireless without that high latency. I wouldn't recommend both of them unless you really need a wireless mouse. You can either get the razer deathadder chroma,g402 or the g502.
https://linustechtips.com/topic/258599-need-help-with-build/#findComment-3532536
Alright, I'm not the best when it comes to anything PC related obviously.
Now, what do you think the best overall gaming mouse for FPS games are? (CSGO, DayZ, ECT)
https://linustechtips.com/topic/258599-need-help-with-build/#findComment-3532686
On mobile so its really hard to link one.
For PSU go for corsair vs450w
For mouse get g502
For keyboard,Are you really sure you need RGB because you wouldnot be watching those glowing lights during gaming.
But.. but.. its pretty  :(  :(
No, I don't need the RGB. Just wanted it, but I guess it's just an expense I don't need.
Would you recommend the K70 or should I switch it to a Ducky or something.
https://linustechtips.com/topic/258599-need-help-with-build/#findComment-3532772
But.. but.. its pretty :(:(
Remember I am not forcing you to change your decision on the RGB one.But you need to consider what I said to you before.K70 cherry mx red is best for gaming.K70 for quality build.
https://linustechtips.com/topic/258599-need-help-with-build/#findComment-3532788
Gigabyte GA-Z97X-UD3H-BK   $99
ram is overpriced,get define r5 instead of r4, my personal favorite is nzxt s340 since it isn't as big as define and enthoo pro,   windforce 970 istead of strix,      small psu if not using sli
i would also consider i7 assuming a year later games might make use of 8 threads
https://linustechtips.com/topic/258599-need-help-with-build/#findComment-3532810
I changed my PSU, changed mouse to g502, and changed to a normal K70 :3
I just realized how much extra I was paying for shiny lights when you asked if RGB was needed.
https://linustechtips.com/topic/258599-need-help-with-build/#findComment-3532823
The Hd558 are surround sound right? So I can hear people behind me, to my left, etc?
https://linustechtips.com/topic/258599-need-help-with-build/#findComment-3532925
