Strange CPU temperature
Go to solution Solved by Godlygamer23,
No. That's fine.
First sorry for my bad english and second i just changed my amd stock cooler with this,Compared with the stock cooler the temps are mutch better now,but one temp is realy hight now and when i had the stock cooler it was mutch lover.
Is this ok, what do you think?
http://postimg.org/image/rm4129qa5/
https://linustechtips.com/topic/258578-strange-cpu-temperature/
That is your maximum temp value. That is the highest value the CPU(or any other component under that section) has hit. The spike in temperature likely has to do with the fact that the CPU has hit full load at one point or another.
https://linustechtips.com/topic/258578-strange-cpu-temperature/#findComment-3532277
If you're very worried about temps, buy a cooler for your CPU.
I Usually recommend the CM Hyper 212 as a good, cheap upgrade from stock, and it's only 45AUD.
P.S - AMD Chips usually run a little warmer than the Intel variant, albeit i'm not a fanboy, just stating the facts, they have higher TDP's & (usually) Clock speeds.
CPU i5 6600K | Mobo Gigabyte Z170X Gaming 7 | Cooling H80i | MSI GTX970 Gaming 4GB in SLi | Geil Super Luce 16GB 3000MHz DDR4 | Intel 330 120GB | 2 x 1TB WD Black | Corsair Air 540 | XFX ProSeries 1250W. | Corsair K70 Anodised Black Cherry Reds | Logitech G502 | Dell U2713HM | Red LED Lighting.
Portable Gamer - Metabox Alpha W370SS - CPU i7 4710MQ | RAM 8GB 1600MHz | Nvidia GTX 860M 2GB GDDR5 | Samsung 840 EVO 250GB SSD | 17.3" Matte Display 72% Gamut
Back-up - HP Pavilion dv6 - Ancient Stuff - P7550 @ 2.26gHz  | DDR2 4GB | Kingston HyperX 120Gb SSD | ATi 4550m (fried)
https://linustechtips.com/topic/258578-strange-cpu-temperature/#findComment-3532294
Even so dont you think that temp are realy hight?Lock at minimum temp.At 1400Mhz is 46C.
And the cooler i have now is deepcool lucifer v2 as i mentioned.
That's with your CPU idling.
https://linustechtips.com/topic/258578-strange-cpu-temperature/#findComment-3532304
What were your maximum CPU temps like with the stock cooler?
https://linustechtips.com/topic/258578-strange-cpu-temperature/#findComment-3532314
Is the cooler mounted properly?
https://linustechtips.com/topic/258578-strange-cpu-temperature/#findComment-3532346
I think so....i'm not realy sure,it was prety hard to mount.If you need any test or if you want i can make a picture of the cooler to see if it's mounter corectly.
This is an older picture with the stock cooler temps.
http://s30.postimg.org/47npq4skx/F_r_titlu.jpg
https://linustechtips.com/topic/258578-strange-cpu-temperature/#findComment-3532356
No. That's fine.
https://linustechtips.com/topic/258578-strange-cpu-temperature/#findComment-3546583
