Finishing my new build
CPU: i7-2600k
CPU Cooler: NZXT Kraken X-61
Motherboard: ASUS P8 Z68-V
Memory: Corsair Vengeance 16gb (2 x 8gb) DDR3 1600mhz
Storage: Intel-730 480gb + Seagate 2TB SSHD
Graphics card: Gigabyte G1 gaming GTX 970
Sound card: Asus Xonar
Power supply: Corsair AX 750W 80 Plus Gold
Case: Corsair Carbide Air 540
I have 2 questions. Should I replace my stock fans that come with the kraken cooler? or is it good enough?
Are the fans that come with the case(AF 140) good enough to keep? or should I get Noctua fans?
Im planning on overclocking both my CPU and GPU
https://linustechtips.com/topic/258564-best-case-fans-to-get/
The AF 140's are definitely good.  But I believe the Noctua's are better still.  I've got SP's and AF's but yet to try Noctuas cos they cost freakin hell over here.  $30+ for a single fan.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/258564-best-case-fans-to-get/#findComment-3532184
If you want as much performance as possible you can change the fans on the AIO to noctua but the difference in temps will only be small. If got care about sound however I would change all the fans to either noctua, noise blocker, Silverstone or be quiet!
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/258564-best-case-fans-to-get/#findComment-3532991
CPU: i7-2600k
I'd definitly advise changing the fans on the NZXT X61 to noctuas, best choice I made and regret not doing it sooner. The difference in noise is remarkable while gaming.
CPU: i7-4770K  Cooler: NZXT X60  GPU: Asus GTX 770 2GB  MB: Asus Maximus VI Hero  RAM: Corsair Vengeance 16GB 1600MHz  PSU: Be Quiet! 630 Watt  Case: NZXT H440
       Storage: 120GB Samsung 840 Evo + 1TB Seagate HDD  KeyboardCorsair K70 RGB  MouseG502 Proteus Spectrum  HeadphoneSennheiser HD598  Mic: Blue Snowball Ice
https://linustechtips.com/topic/258564-best-case-fans-to-get/#findComment-3533127
Money is no object fans: Noctua, Be Quiet! and Noiseblocker.
Money matters: Not Noctuas, but Corsair fans do offer good value when you buy the 2 packs. Cougar fans are also well regarded for their price. Akasa is another option, their Black Apache have solid specs.
Do keep in mind that even Noctuas (and we're not even talking the louder black industrial units) get obnoxiously loud at 12v just like every other fan meant for performance. Fan control of some sort is def recommended.
https://linustechtips.com/topic/258564-best-case-fans-to-get/#findComment-3533838
Use the ebay machine. Bought 3 noctua 120's for 30 bucks on here. Bought four of the 2k rpm noctuas for under 30 a piece. Well worth it to me. Getting the same performance that all my corsair fans offered at max speed as the noctua's at 800-1000 rpms. 30 bucks for a fan is cheap compared to the rest of my system.
https://linustechtips.com/topic/258564-best-case-fans-to-get/#findComment-3537174
I was able to pick up 2 of the NF-F12 industrial PPC 2000 for 20 CDN each just now so Im happy
https://linustechtips.com/topic/258564-best-case-fans-to-get/#findComment-3546292
Agreed - I used the AF140's, they're good for the price.  Noctua is better but I preferably stay away from the light brown color.  Eww... doesn't really fit with any computer at all.
What is the meaning of life?  Well, 42 is the meaning of life, so half of 1 life is 21.  Half-Life 21 CONFIRMED  WHEN WILL THE i9 COME OUT?  LINUS = :P
https://linustechtips.com/topic/258564-best-case-fans-to-get/#findComment-3551686
