Hi LTT it's been a while, and I need a bit of advice. I'm getting either a new GPU or CPU for black friday but I'm not sure which is a better choice. I MIGHT get an Intel processor or I might just get an 8370E because my computer's performance with Windows has been increasingly poor, but I also need a new GPU. Is it worth it to get a new FX (or MAYBE an i5-4440) or should I get a Sapphire Radeon 290 Tri-X?
CPU: AMD FX-8120 | CPU Cooler: Thermaltake Contac 30 | Motherboard: GIGABYTE GA-990FXA-UD3 | Memory: Kingston 16GB (4 x 4GB) DDR3-1333 | Storage: WD 1TB | GPU: Gigabyte Radeon HD 7870 | Case: Thermaltake Chaser MK-I | PSU: Thermaltake Black Widow 850W
https://linustechtips.com/topic/258337-need-help-with-upgrades/
I'd go for a 290, if you overclock the 8120 it should be a good combo :)
I have my 8120 at 4.0GHz and it's hardly noticeable anymore
https://linustechtips.com/topic/258337-need-help-with-upgrades/#findComment-3529938
Getting a 290 will be a much bigger upgrade than getting another amd cpu, but gettin an intel cpu would help quite a bit as well.
https://linustechtips.com/topic/258337-need-help-with-upgrades/#findComment-3529950
Nice! with that being said, go for the GPU upgrade
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
https://linustechtips.com/topic/258337-need-help-with-upgrades/#findComment-3529952
Any advice on how I can get my PC up to speed again? I'll be getting an SSD soon enough but anything I can do until then?
https://linustechtips.com/topic/258337-need-help-with-upgrades/#findComment-3529960
Every once in a while I reinstall windows, it helps a lot :)
https://linustechtips.com/topic/258337-need-help-with-upgrades/#findComment-3529962
Might as well just wait until I get an SSD to do that then
https://linustechtips.com/topic/258337-need-help-with-upgrades/#findComment-3529980
Good idea, good luck with the upgrade! :)
https://linustechtips.com/topic/258337-need-help-with-upgrades/#findComment-3529990
