I've recently replaced my GTX 660 TI PE, and bought my self a Gigabyte GTX 970 reference card, but I've noticed that the performance jump isn't as big as i expected, or as projected by benchmarks. I then started to watch numerous benchmark videos of different games, and only to find out i'm not squeezing out the same performance of my card.
  • CPU
    I5-3570k
  • Motherboard
    MSI GD-80 z77a
  • RAM
    16GB DDR3 Vengeance 1600 Mhz
  • GPU
    1x Gigabyte GTX 970 (non G1)
  • Case
    Cooler Master Haf 922
  • Storage
    256gb Sandisk SSD | 160gb WD Blue 7k 16mb Cache
  • PSU
    Antec 750 watt (80+ bronze)
  • Display(s)
    Samsung 720p 42' TV|LG Flatron e2250 (1920x1080)|Nivdia shield
  • Cooling
    Cooler Master LED 200mm fans 2x|Cooler Master 120mm fan| Cooler Master Hyper 212 EVO
  • Keyboard
    Cooler Master CM Storm ($30) red
  • Mouse
    Razor Naga Blue & Cooler master CM Storm mouse
  • Sound
    Siberan v2 Headset & B&W fronts, infinities in the back, and energy 10' sub woofer
  • Operating System
    Windows 7 & Android
I've benchmarked a series of games, but stills struggle to find out the issue.
Games I've bench marked:
Far Cry4 30-45fps (hits 50 rarely, and never goest to 60) Reference video for the benchmark:http://www.youtube.c...h?v=dqiOX-4fjdw
Arma III 15-high 20's
3d Benchmark (skydiver default) my score was: http://www.3dmark.com/3dm/4839575 22029
Others got higher scores, but i don't know why? I feel like my PC ins't pushing what it's suppose too. http://www.3dmark.co...0&cpuName=Intel Core i5-3570K Processor&gpuName=NVIDIA GeForce GTX 970
I didn't replace my GPU solely for getting better frames, but i also had issues with my PC, and i suppose i still do now, which leaves me to wonder: what part is bad? The problem is usually a desktop problem, but it tends to happen when i leave my PC on for long periods of time. The task bar form time to time will glitch out, and icons won't show, as shown in the pictures. During the time that this bug is active, my PC is prone to lock ups, and blue screens, and some times it would notify me that my Nivdia drivers had failed, but that has yet to happen on this card, nor the blue screen, but lock up in a black screen did, and it forced me to restart my PC.
The third photo with the bad resolution is when uninstalled the Nivdia drivers, and the problems persisted
I've also received a debug code:03 a few times during lockups, and blue screens, so what does this mean? I've had a post about it before http://linustechtips...and-hangs-help/
I destroy my enemies when I make them my friends.
~Abraham Lincoln
In times when we are on the brink of destruction, war, and loosing ourselves, let's remember a basic fundamental element of love, forgiveness, and understanding; God bless!
https://linustechtips.com/topic/257673-help/
Drivers? Overclock it?
Clean install, and i shouldn't have to :D
Are you using the latest drivers and same ingame settings as the benchmarks you are looking at?
Yep, i just reformatted, and still not getting the same performance as others :S
~Abraham Lincoln
https://linustechtips.com/topic/257673-help/#findComment-3523202
If you have dual monitors, run openhardwaremonitor on your second display while running a benchmark or game, and keep an eye on the CPU and GPU temperatures, loads, and speeds... see if you can spot any thermal throttling due to high temps.  Watch if the GPU is actually being put on 100% load the whole time.
https://linustechtips.com/topic/257673-help/#findComment-3523214
I don't have a second monitor atm :S. It being at 100% all the time is bad? What would be the cause, and the solution then?
~Abraham Lincoln
https://linustechtips.com/topic/257673-help/#findComment-3523226
We want to see if it's actually being used at full capability.  If there's a different component that is holding the rest of the system back, the GPU might not actually be operating at full capacity to begin with.
https://linustechtips.com/topic/257673-help/#findComment-3523234
Gpu operates at 100% while cpu sits pretty soild on 50%, so is this good? :o
~Abraham Lincoln
https://linustechtips.com/topic/257673-help/#findComment-3523237
What temp is the GPU hitting during your gameplay?
Corsair 5000D / Intel Core i7-12700KF / Arctic Liquid Freezer 3 360mm / MSI Meg Z690 Ace / RTX 3080 Ti Founder's Edition / 64GB Corsair Vengeance RGB 3200 MHz CL32 / Corsair RM1000X / 1TB ADATA SX8200 Pro (Boot) / 2TB Acer Predator GM7000 Gen 4 (Storage) / MSI MPG271QRX-QD / MSI Mag 274QRF-QD / LG CX 55" / G-Pro Wireless
https://linustechtips.com/topic/257673-help/#findComment-3523238
Try changing your power settings place it onto high performance and see if that changes anything
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/257673-help/#findComment-3523247
60 degrees
How do i do that? :o
~Abraham Lincoln
https://linustechtips.com/topic/257673-help/#findComment-3523271
That's weird that you're getting less than average FPS... seems like everything should be running ok?
You can change your power options in Control Panel -> All Control Panel Items -> Power Options
My only suggestion now would be to overclock I guess...
https://linustechtips.com/topic/257673-help/#findComment-3523322
