Yes. They will dim according to power/speed
https://linustechtips.com/topic/257493-led-fans-fan-controller/#findComment-3521123
Are there any red LED fans in 120mm and 140mm that have separate LED and fan power connectors?
A few, the ones I have come across will have a molex connector and a little switch to change the speed. Then there are some which will have no speed control.
https://linustechtips.com/topic/257493-led-fans-fan-controller/#findComment-3531188
