sry idk which forum was the right one
im building my first pc,
and idk what should i do with the cables.
there are too much cables that i dont know how to connect
pictures are added
first of all this is my mobo:
http://postimg.org/image/9t7hf5z4f/
gigabyte z97 gaming 3
the first cables - the cpu cooler (h100I)
where should i install them?
http://postimg.org/image/804kqudxr/
the next ones are the case ones (arc midi r2):
http://postimg.org/image/rffcjy77z/
http://postimg.org/image/lfrlgamfj/
btw- can i use the spare fan (took it from the case top cuz i used the place for the pump) in here?
http://postimg.org/image/5t4xgny1b/
the last ones are that ones:
http://postimg.org/image/vneq6fy1b/
they comes from the top of the case
and another problem i got..
i have a SEA-SONIC 850X psu,
with a fan on top
http://postimg.org/image/jrsg1n8jz/
the fan should be face to the top or bottom?
1. everyone tells me bottom
2. the instructions warns about doing that:
http://postimg.org/image/rlt1n1gcv/
look where im placing my finger
thanks a lot ! :)
https://linustechtips.com/topic/257456-cable-problems/
what what?
its a forum for asking questions about hardware isnt it?
yea it is just the post was confusing to me
https://linustechtips.com/topic/257456-cable-problems/#findComment-3520797
Psu facing with fan downwards
first of all thanks for the fast answer!
im a bit confused..
the place u told me to put the H100I got 4 pins and the h100I just 3 holes..
and what is the top fan 1&2? got only 1..(actually its a back top fan)
https://linustechtips.com/topic/257456-cable-problems/#findComment-3520905
im a bit confused..
Yeah its a bit confuseing with your amount of pics. Rear exhaust then goes to SysFan1. Casefans goes to sysfan headers. The connection with the h100 is fine. There is a notch on the connetor so it will only fit facing left from your ram slots. The fans on the radiator goes the 3pin connectors comming from the pump. While the usb 2 header from the pump goes to "usb panel" left hand side from the front i/o on the bottom of the board.
https://linustechtips.com/topic/257456-cable-problems/#findComment-3520949
 oh lol sorry about that
thanks a lot ! installed all the fans, but what usb are u talking about? (i guess its related to the pump but didnt get there yet)
last things:
the top cables from my case? how do i connect them to where?
and what cables should be connected to the psu? (for motherboard, 1 gpu, ssd and hard drive and for the led of the cooling)
thanks !
https://linustechtips.com/topic/257456-cable-problems/#findComment-3521052
Here's the full circuit. Top cables from the case? I quess you mean the power button and such.
Power button -> pw sw
Reset button -> rw sw
Power led -> pled +/pled-
Hdd activity led -> hdd+/hdd-
Front audio jack -> faudio or hdaudio or ac97
This is the usb cable from the pump. The right last cable coming with h100i
For the gpu 2 pieces of 6+1 pcie connectors from the psu
For hdd and ssd 2 pieces of s-ata power connectors
Circuit
https://linustechtips.com/topic/257456-cable-problems/#findComment-3521133
Circuit
i actually talked about those: http://postimg.org/image/vneq6fy1b/
i cant find a place to use them
https://linustechtips.com/topic/257456-cable-problems/#findComment-3521250
This is the fancontroller from the case itself. You can leave them unused as its better to let your fans spin up from the mainboard software.
and if i want them to be controlled from case is it hard to connect? i want all the buttons to work (idk why but thats important a bit to me)
https://linustechtips.com/topic/257456-cable-problems/#findComment-3521333
You would use the big connector and connect it to the psu output and the 3 connectors would be connected to the fans instead of useing the sysfan connectors from the mainboard.
perfect ! thanks, i connected all the cables, only got to connect the sata(or data idk the name) to the motherboard or psu and to the hard disks and the cooler and itll run( the pc) ?
https://linustechtips.com/topic/257456-cable-problems/#findComment-3521386
Yes, it should run then. Are there any cables left? For the sata, they only can go in one way, but sometimes it needs just a little bit of force. I had my PC not boot, because the Sata Power not plugged in all the way.
Intel 4790k | Asus Z97 Maximus VII Impact | Corsair Vengeance Pro Series 16 GB 1866Mhz | Asus Strix GTX 980 | CoolerMaster G550 |Samsung Evo 250GB | Synology DS215j (NAS) | Logitech G502 |
https://linustechtips.com/topic/257456-cable-problems/#findComment-3521438
Just saying http://www.timeanddate.com/time/zones/cet :( Sorry but my alarm gets off at 5am. I need my sleep didn't expect this to take so long.
But leaving a qualified nightowl to finish this
@LarsReviews
thanks a lot for all ur help !! really appreciate it !
there are like 20 cables left xD
the motherboard place with the "sata express " and "sata 3" its empty, i got the cables but idk how and to where should i connect them,
and i connected a sata cable (got 4 - longest one) from the psu to the hard drive, to the ssd , theres an unused one and then to the cpu cooler, is it ok? just looked good xD
https://linustechtips.com/topic/257456-cable-problems/#findComment-3521492
Totally ok. You could even use a separate sata cable for each device. Is the pump and the cpu cooler fans running?
https://linustechtips.com/topic/257456-cable-problems/#findComment-3521519
idk, i didnt turn it on because the sata express got no cables in it and in every tutorial ive seen (of linus) he used sata cables ( and i got 4 - 2 types)
how do i connect them?
and ofc i need to connect the gpu but its easy as pie :)
https://linustechtips.com/topic/257456-cable-problems/#findComment-3521535
How many drives do you have? You don't need the sata express.
It looks like you have a SSD and a HDD. For now, plug both Sata cables in, but only connect power to the SSD. After installing windows, turn the PC off and plug in sata power to the HDD. For the SSD you want to use Sata0 and for the HDD Sata 1. (The order doesn't matter, but I just do that so it is more organized if I ever need to troubleshoot. )
https://linustechtips.com/topic/257456-cable-problems/#findComment-3521620
if i got u right-
i connected to the sata 0 and 1 - 2 cables- 1 to the ssd (0) and one to the hdd (1)
from the psu i connected 1 sata (with 2 plugs) one plug to the ssd and one plug to the hdd but only the ssd one is connected?
https://linustechtips.com/topic/257456-cable-problems/#findComment-3521706
if i got u right-
how does your sata cable look like
This is Sata Express:
https://linustechtips.com/topic/257456-cable-problems/#findComment-3521730
like the red one
ok, that one is just called sata. The data cable can be plugged into the HDD, but the power cable for the HDD should not be plugged in. When installing windows, it can happen that some stuff is installed to the HDD. To prevent this, the HDD power is unplugged, so the windows installation can't right any data to it. After the installation is done and you where in windows for the first time, you can then plug in the HDD power.
Just want to make sure that you use the SSD for Windows. If that is taken care of, you should be able to boot for the first time. Before installing windows, you should go into the bios and watch the temp for a view minutes also to check if the cooler is working.
https://linustechtips.com/topic/257456-cable-problems/#findComment-3521761
data cable? u just typed wrong or am i missing a cable?
and what is a power cable? like.. the sata cable from the psu?
and why do i need the windows on ssd? i thought only for after effect adobe
https://linustechtips.com/topic/257456-cable-problems/#findComment-3521770
