So I got my case, built the computer, turned it on, happy that it turned on, I realized I forgot the optical drive. I then proceeded to turn it off, only to see, that the button was stuck in the case, it wasnt causing it to stay on, or stay off, I just have to push way too hard for my own comfort on that power button for it to turn on. I learned that to install the optical drive you have to take off the front bezel, (wierd but eh) it was there I learned, there was a power button extension, on the actual lead itself. If I click the extension in, sort of like a detonator it turns on just fine. Any help?
fx 6300 - sapphire dual x r9 270x - Zalman z9 - Evga 500B - Cooler master hyper TX3 - Win. 8.1 - Asrock 970 extreme 3 r2.0 - Crucial ballstix sport 8gb (2x4) - WD blue 1TB - some random optical drive for 11$
https://linustechtips.com/topic/257271-case-power-button-stuck/
What case are you using?
Zalman z9, non plus.
https://linustechtips.com/topic/257271-case-power-button-stuck/#findComment-3518848
Open up the top panel, and reset the connection. IMO dont use Zalman, meh cases. Use Corsair, Fractal Design or Phanteks
Current Rig:   CPU: AMD 1950X @4Ghz. Cooler: Enermax Liqtech TR4 360. Motherboard:Asus Zenith Extreme. RAM: 8GB Crucial DDR4 3666. GPU: Reference GTX 970  SSD: 250GB Samsung 970 EVO.  HDD: Seagate Barracuda 7200.14 2TB. Case: Phanteks Enthoo Pro. PSU: Corsair RM1000X. OS: Windows 10 Pro UEFI mode  (installed on SSD)
Peripherals:  Display: Acer XB272 1080p 240Hz G Sync Keyboard: Corsair K95 RGB Brown Mouse: Logitech G502 RGB Headhet: Roccat XTD 5.1 analogue
Daily Devices:Sony Xperia XZ1 Compact and 128GB iPad Pro
https://linustechtips.com/topic/257271-case-power-button-stuck/#findComment-3519140
