Hi guys,
My build Im planning on doing soon will be overclocked. The only issue is that I don't know how to overclock my system haha
I have a  Intel Core i5-4690K running on a Gigabyte GA-Z97MX-Gaming 5 motherboard. What would the steps required be to stably overclock my cpu?
​Thanks
https://linustechtips.com/topic/256979-overclocking-help/
Eventhough this is for the Pentium, the same principles are in play
You basically raise the multiplier untill it's unstable, and then you raise the voltage.
Do you have a K-skue processor and adequate cooling?
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/256979-overclocking-help/#findComment-3515630
Do you have a K-skue processir and a adequate cooling?
Yup, 4690k and H105 Extreme water cooler
https://linustechtips.com/topic/256979-overclocking-help/#findComment-3515648
Then you are all set for overclocking.
Let's hope you have faired well in the silicone lottery.
https://linustechtips.com/topic/256979-overclocking-help/#findComment-3515659
hahah I remember in one of linus' other overclocking videos he stated that you can have a k series that won't overclock at all and others that just go insane..I Do hope i win!
https://linustechtips.com/topic/256979-overclocking-help/#findComment-3515681
